Attn 955 owners with headlamp wiring and turn signal failures.
Last year I had to replace the entire LH headlamp assembly in my well-maintained '06 CTT with 90K miles because the molded-in contact for the front turn signal had eroded from arcing and corrosion, and was irreparable. It appears to be aluminum, rather than brass that would last for eternity. Now the R turn signal contact has gone too. This is a ridiculous failure that's more than ridiculously expensive to correct. I also see many reports here of headlamp wiring insulation crumbling. These are preposterous flaws of fundamental safety items and common sense says it's reasonable that they should last decades. They should be NHTSA-mandated safety recalls.
These headlamp wiring and TS failures are reported here frequently, so I checked the NHTSA website to see if there was any action. I was quite surprised to see that there were NONE reported for MY 2006 Cayennes. I assume that similar failures for other 955 model years are similarly unreported. So I filled out a report on my failed front turn signals contacts, and I recommend that others who've had them, or the crumbling insulation issue, go to the NHTSA website and report them, with a photo of the failed part or area if possible. All you need is your VIN, it takes just a minute or two, it can't hurt and it may finally get Porsche's attention.
I replaced both headlight harnesses (about 10 inches long) on my car and they were *toast*. Basically no insulation left at all. Lets hope that the new harness is of higher quality. Further more, the inside of the Xenon housings also revealed a lot of insulation chipping off, but the good news is there is a low chance of either water/dirt/corrosion and little chance of shorting out, etc. Liquid electrical tape helps here.
-Will
-Will
Yep. I just went through this so I feel your pain! The entire wiring assembly inside both of my headlights were rotted out. I used marine grade shrink wrap over each of the individual wires in order to fix them. No doubt the job was tedious to cut each wire, slide shrink over them, and then reattach them together. This repair set me back about $15 in materials and a few hours of my time. Maybe I will fill out a report too, but won't hold my breath about a recall being issued.
The burnt contacts are a result of poor contact with the receptacle socket.
The solution is to modify the plastic headlight plug holding bracket on the vehicle side.
You cut off the ends of the retaining bracket with a Dremel allowing the electrical plug to be free from the holding bracket.
You then manually insert the plug into the headlight upon installation and manually remove it when you remove the headlight.
I modified mine 8 years ago and have never had a problem again with the turn signal messages.
My point is that it's ridiculous to have to mod the turn signals on luxury performance car just to keep them functioning beyond a few years. Porsche should be ashamed of such an obviously lame design for such a basic function. The contacts that are molded into in the headlamp for the removable bulb holder burned through on my car. If there's DIY fix, I'd love to see it.
I'm surprised nobody has made an aftermarket alternative to the OEM headlight assembly (that I'm aware of). It is such a troublesome design that one would think that an aftermarket product would've been developed.
I agree. My 08 Touareg has the same bare wires by the headlights...I put electrical tape on them. No aftermarket because these vehicles are no longer being used in any large numbers due to design/build errors. Sunroof drains, hangar bearring, scored cylinders, wire harness under seat failing, the list goes on...
Received 1,141 Likes
https://www.jcwhitney.com/details/Po...SP5080967.html
https://www.autozone.com/collision-b...e/cayenne/2006
https://www.europaparts.com/headligh...563115751.html
https://www.autohausaz.com/porsche-a...placement.html
https://www.partsgeek.com/catalog/20..._assembly.html
etc..
I love the way people assume things, like "how can he be so stupid?" I've googled it plenty of times, thank you very much. I'm talking about the entire assembly including the receiving tray, wire harness, locking mechanism, etc. It's a lousy design in its entirety.
Best Deal available when living overseas (RockAuto)!
Great pricing from eBay, 1/3 the price from the Porsche Dealership! Build quality extremely high, better than new!
