2008 Cayanne Stuttering - what could this be?
I have just bought a 2008 Cayanne S - only has 100km / 60k miles on the clock. Has been doing great but now it has started of stuttering. When sitting in traffic there is a very slight jolt from the engine where it sort of judders every once in a while. This also happens accelerating somtimes.
JKust wondering if this is c common issue or can anyone suggest what it might be?
Thanks.
Thanks.
Concur. I had the same symptom in mine (and worse), changed out the coils and it cleared. And that is the cheapest and easiest place to start.
Quote from the Saab moderator when I owned a 9-3 Aero: "I'm not saying it's the coils, but it's the coils." Saabs ate coils for lunch. The fix was AutoZone coils with a lifetime warranty and were proper Mitsubishi OEM in a Duralast box.
Great How-To if you are so inclined: https://www.youtube.com/watch?v=a2NxJA2ovf4
https://www.fcpeuro.com/products/porsche-ignition-coil-bremi-sti-94860210414
Bremi vs Porsche vs Beru... IDK you be the judge. FCP Lifetime Warranty!
Also do the plugs while you are there... IMO switch to Iridium which should be good for 100k (in normal cars, Porsche is weird on their plug intervals)
Thanks guys - I brought it to an independent specialist and typical it was not happening so he was unable to identify the problem exactly - but as you say he suggested the coils. He said there were a few faults but nothing specific to the cols so he reset them and said drive for a week and come back to him. He said my oil separator needs replacing and I probably need a major service.
He also said my front right show looked low - might have a leak so I'll have to replace them both. That wont be cheap!
Go to the thread titled:
955/957/958 Cayenne DIY: Wiring problems due to moisture
Last edited by jeffcatl; 02-04-2019 at 09:29 AM. Reason: Update with link to resolution
