Was using a charger with jump starting (60A output) to start a 2004 Cayenne S
(60,000km on the odometer) Now the car is completely dead with no Interior lights anywhere. Car was sitting there with a charger on timer charging for maybe an hour per day for a month while I was on vacation. The CD/radio was making a clicking sound prior to and I thought the battery needs a boost to start after a month. Now nothing!
Well almost nothing - behind the dash board there is some very weak clicking/sound.
Thought I ask here first - before towing it to the Porsche dealership.
Why a high power charger for 1 hour a day? That could blow up your car if the charger is boiling hydrogen and oxygen out of the battery (less likely if the battery is AGM or Odyssey/Optima-type battery which are gel-impregnated fabric rolled up like toilet paper in each cell). Under some conditions, powerful battery chargers can even cause the battery case to swell and split. An hour a day on a high power charger like that connected to a car thats not being driven at all... that is 30 hours of charging on a charger that can deliver up to 60 amps? You didnt think that was massive overkill? One hour of charging with that charger is far more than you need for 30 days of sitting unused. You have probably boiled the battery to death--killed it dead. This is why they make Battery Tenders for $40 to $60... they cant damage a battery when left connected 24/7. I would take the battery somewhere they can test it. if the battery has conventional screw off caps, and it was a wet (liquid acid) battery, the acid should be visible with the cell's cap off so bring a flashlight when you check. if you are lucky, youll only need a new battery. You cant save a battery that has been overcharged. 20Amp-hours a day (20 amp charger, 1 hour a day) would STILL be overcharging the battery. You probably didnt need more than 10 or 15 minutes on your charger to top off the charge after sitting for a month unless there is a parasitic load on the battery that accelerates discharging.
I'm a little consumed by the original post. Was the 60A jump starter the same charger being used for 1 hour per day with the timer or was it a normal charger and then you tried to jump start it with the 60A jump box without success?
If the battery is internally shorted from overcharging, the jump box will do nothing. You'd have to disconnect the battery to get it out of the circuit and then use only the jump box or a spare battery.
Scoot is certainly correct here though, that a Battery Tender was the proper way to do this rather than a regular charger and timer. Was the timer the battery charger was plugged into rated to handle the amp draw of the battery charger as those timers are usually only made for lights. You may have cooked the timer or blown the outlet fuse where it was plugged in the first time it turned on, which means you got no charging at all for the month you were gone and the battery is now completely dead.
One time I tried to start the Cayenne with a 40a charger connected directly to the battery. The whole car went completely dead. I took the cables off the battery and discharged all the static electricity and all was well. Never again.
can you talk about what is “discharged all the static electricity”?
Received 1,140 Likes
Yes. Charging is only for minutes a day at regular settings. NOT at jump start settings. I switched to jump starting / high power because I was not going to drive any distance as I thought starting drains the battery and not driving won’t charge the battery. Prior to starting the radio/CD player was making a clicking sound.
Will not proceed with this as essentially we are talking about reset the circuit without the battery and I have no access to disconnect the battery ?
touch both the + and - together!? I will use a separate jumper cable as the battery is under the front seat and no power means I cannot move the front power seat at all
Have it towed to a mechanic.
As promised earlier:
editosted in the wrong thread
Advice needed, please.
My 2019 Cayenne with a LiFePO4 battery will jump start with the NOCO 10 Genius 10. After jumping, I drove it for about 40 miles to try and charge the battery without success. The car is immediately unresponsive as soon as it is switched off. My husband tried to charge it with a NOCO GBX45 overnight without success. The indicator lights seemed to work correctly but the car remained unresponsive.
I spoke to the Porsche Service Manager who stated they are replacing the Cayenne batteries under the Emissions Warranty. However, the dealer is 1 ½ hours away (105 miles). All but 5 miles is Interstate driving. It’s a $600 tow charge. The dealer suggested jumping & driving it while leaving the NOCO attached to the battery in the floor.
Questions:
Can I jump start the car & drive it to the dealer?
Will it damage the vehicle?
Will driving it that far damage the clutch? I was told it would.
Questions:
Sing up for AAA+ plus and next week start the drive and when it shuts off call triple AAA to tow you the 100 miles to the dealership if that's the closest one. The plus level membership gets you 100.mile.towing range.
