Air suspension failure
Which fuse is for air suspension compressor on 2008 Cayenne Turbo near the battery? |
Not sure on your year model but the info is located in the owners manual. I know it is not too hard to find s PDF of that or an image of that legend online. You should try that.
Do you hear the compressor running and then get the message or not hear the compressor at all. If the former, it's because there's a leak or the compressor needs to be rebuilt and the car is looking for a certain pressure to be achieved in the tank within a certain amount of time. If that doesn't happen, you get a failure message. This is the issue if the car will still go up and down, like normal, but seems to take a while to do it.
If it won't move at all, then could be the fuse or the compressor itself. |
No compressor sound, just message red “Sust Failure” when cornering starting and other times. Manual says “ fuse 27 “ in rt dash side fuse box for “ Leveling Control” only 15 Amp fuse. Expected 40 Amp fuse? No DIAGram for fuse pal in battery box in manual? ”PET” says there is a 40 Amp fuse in the batt box, but; no label? |
Which fuse in batt compartment is foe compressor?. Thanks |
Anyone? |
Actually there are 3 fuses associated with suspension control.
The ride height control module is powered by fuse 43 (10A) and fuse 27 (15A) in the right fuse box under right side of dash. The support relay which powers the compressor is fuse 13, a 40A which is in the battery fuse box. I posted a suspension system wiring diagram many moons ago, the search feature should direct you to the thread. The electrical system diagram is common to m.y. 2004 to 2010. |
Originally Posted by v10rick
(Post 15571573)
My manual says it’s fuse 27 and 48 in rt side dash for leveling control. Is it fuse 13or relay 13 at 40 Amps in the battery compartment? Thanks |
Fuse #13 is 40A at the battery fuse box. The location of the support relay has been a mystery.
I recall a post mentioning it is under the drivers side dash. Don't know that for certain. |
Thanks ageain! |
Wil it hurt to drive it with a bad compressor? |
