New Bore Scoring Survey 955/957, 2003-2010
#61
Received 1,140 Likes
Anyone with ideas?
#62
Found out how to do it - but it requires that the creator (who is someone besides me, I just edited and put it together) - make it viewable. I've asked for that to happen and will post a link for it as soon as it is.
#63
Thanks to Robb (IB Staff) - we have this link: https://docs.google.com/forms/d/e/1F.../viewanalytics
That will allow you to view the results without having to log into Google..
#64
#65
So the only 100% certainty in these results is that you should modify your Cayenne, which will prevent the problem from occurring, as 100% of reported failures resulted on non-modified engines.
Guess I'm all set.
Kidding of course, but interesting that only 13 people answered that question for some reason.
Guess I'm all set.
#67
Missing is the location of owner/vehicle - since I believe that climate is the main factor that causes these failures it is important. I know of 2 more failures in my town from just the last 6 months. Cars that do not get freezing temps will likely not see this.
#68
But as a counterpoint, I'll say that 100% of my Cayennes (one, a 2004 S) have had the bore scoring problem, and I am in the SF Bay Area (and the car has lived here since new) where we hit freezing about once per year. So from my sample, 100% of the non-freezing cars have scored. Maybe I should follow Petza914's advice and modify the engine, since 100 * 0 = 0.
#69
I'm still not convinced the issue is one of improper tolerances from the factory. It makes no sense.
If the bore scoring, as it relates to tight tolerances, was a thing from birth of an engine, damage would happen immediately, when intolerances at their tightest. Not 50-90k miles down the road when everything is essentially much "looser."
There is another factor that's being overlooked.
In the 928 world, catastrophic engine failure was happening to engines attached to automatic transmissions. Failure was happening around the same time as the Cayenne .
High flex plate load was the cause of the failures.
#70
As a clueless engineer who has yet to have to do a post mortem on a bore scored 4.8 engine (crosses fingers at 161K miles). The failure mode appears as bore scoring followed by rod knock and if not fixed with in a few hundred miles with a rebuild / new engine is a rod through the block. I have noticed that people hear their engines valve lifters getting louder as time goes on which is common on direct fuel injected engines as in the cayenne. I propose the wear is not from bad fitment of the pistons to the cylinder but of a valve lifter wearing out causing complete engine failure. The failure mode that requires the least assumptions given the mean time to failure in this survey (beyond owners lying about oil changes) is carbon buildup on the intake valves causes dragging on a tippet releasing particulate into the oil which catches on a piston ring causing galling on the mirror polished cylinder walls. this would cause rapid deterioration of engine health. I vehemently disagree with the idea that tight tolerances alone are responsible for the bore scoring issue on the 957 4.8L engines. If cold temps and tight tolerances alone were responsible for the issue the all northern living cayennes should have died within a year or three. I propose the actual failure path on these engines is a valve lifter wearing out letting aluminium into the oil the aluminium particulate gets between the cylinder wall and mirror polished cylinder galling the cylinder wall causing an exponential reaction resulting in the failure of the engine. I may be crazy but this is the most rational explanation i can derive. let me know what you think.
#71
It looks like in the Porsche DFI motors that the injector pulse might actually wash the back of the intake valves, and be the reason that our motors don't build up carbon on the intake valves the same way BMWs and other DFI motors do, requiring a decarbon treatment in as few as 35,000-50,000 miles.
For any of the 08 owners with scored bores, what did the carbon buildup on the intake valves look like when the motors were torn down?
#72
#73
The carbon or aluminum theory certainly sounds plausible. I wonder if any of the scored motor owners ran regular UOA on their oil changes and if they say any elevated aluminum readings prior to the noise that meant the bores were scored. If so, elevated aluminum readings could trigger a boroscope and maybe the heads could be rebuilt before the aluminum scores the cylinders. Alternatively, maybe once the elevated aluminum is there, its too late already and the damage is done and unpreventable.
#74
#75
Just thought I'd distill down some of the results from the bore scoring survey.. and this is the record of reported failures:
I find it interesting that there were only 3 failures reported occurring before 60,000 miles (and out of those, only 1 before 30,000 miles.) The survey results included 168 vehicles - 23 reported failures (13.7%) The failures were almost equally distributed between normally aspirated and turbo engines (putting to bed the theory that turbos were less prone to failure due to the under-piston oil squirters.)
