Can't set the date!
Old 09-24-2018, 05:44 PM
OYM
OYM's Avatar
Default Can't set the date!
Hello
Another question for the experienced amongst us
I can set the time OK but there seems no way to set the date on my 2005 Cayenne Turbo
On the main screen I can adjust the time and adjust the date order but there seems no provision to set the actual date?
Old 09-28-2018, 02:51 AM
OYM
OYM's Avatar
Just wondering if anyone has any thoughts on this?
One thing to mention - My Navi is not picking up satellites and is 'off map' so Ive checked it out and ordered a new antenna - will this be stopping me setting the date?
Old 09-28-2018, 07:51 AM
hahnmgh63
hahnmgh63's Avatar
You set the time and date through the dash display, not the PCM head.
Old 09-28-2018, 07:52 AM
hahnmgh63
hahnmgh63's Avatar
If you don't have the manual for your Cayenne PM me and I can send you a pdf version for the 2005.
Old 09-28-2018, 12:49 PM
OYM
OYM's Avatar
Thanks. I've got the manual but on the setting time/date it doesn't tell me how to set the date - just the date format.
I've tried via the PCM and the dashboard.
Please can someone help as it's doing my head in
Many thanks
Old 09-29-2018, 08:23 AM
hahnmgh63
hahnmgh63's Avatar
That is strange then. Mine is settable under the dash,
Old 09-29-2018, 11:49 AM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
I'm not sure about the PCM 2.X versions but, on the PCM 3.0, to change the date:
a) Press INFO button
b) Press OPTION button
c) Select SET PCM system, DATE & TIME, DATE
Old 09-30-2018, 01:28 AM
OYM
OYM's Avatar
Thanks Andy
Mines a UK car and I can't see an 'Option' button...Any ideas if there's an equivalent?
Old 11-29-2018, 07:59 PM
Libast
Libast's Avatar
You ever figure this out? My date just disappeared with no way of setting it. Seens stuck on 7/7/2000 on the PCM options
Old 12-01-2018, 06:47 PM
golden cayenne
2nd Gear
golden cayenne's Avatar
ok mine just got stuck on 07/07/2000 two days ago and see no way to change the date
Old 12-01-2018, 08:47 PM
Libast
Libast's Avatar
Haha man same boat. I have tried resetting PCM, pulling fuse.. it just does not want to update at home.
Old 12-02-2018, 02:11 AM
OYM
OYM's Avatar
The problem I had with mine was the GPS antenna - Nav was down and couldn't set the date. Replaced the antenna and the Nav came back online and then it was possible to set.
Old 12-02-2018, 03:00 PM
golden cayenne
2nd Gear
my nav and gps is working fine there is no "options" choice when i put it on "info" and mysteriously the date advanced from 07/07/200 to 07/08/200 somewhere between 200 PM and 400 PM i can live with the wrong date it just annoys me every time i look at it
Old 12-02-2018, 03:58 PM
Libast
Libast's Avatar
It is annoying me because I like the main screen showing me time date and radio info. Now the date area is just blank.
I wonder if we got a bum GPS signal and our units responded appropriately? I will be taking it into my Indy for an oil change soon at hopefully they can PIWIS it
Old 12-02-2018, 07:20 PM
james brown
james brown's Avatar
the date is automatically set by the GPS system, so says my service advisor and i have never had to set it so i didn't dig deeper 2008 2.1
Quick Reply: Can't set the date!
