Burnt Exhaust Valve - what to do?
Hello everyone,
This is my first post here on rennlist, but I have been lurking for a while. Need some help with my 2005 Cayenne turbo. Basically, I got the car for very little, and am fixing it up. The car has been diagnosed with a burnt exhaust valve. Everything else is ok otherwise. Cylinder 3/bank 1.
I'd love to just pull that head and get the head repaired...is that even possible with the engine in the car? Meaning, if I have to pull the engine, it might just be cheaper or easier to replace the entire motor.
let me know what you guys think!
Thanks,
Will
Thanks,
Will
Here's some great reading for the weekend to inspire you:
https://rennlist.com/forums/cayenne-...fr-7163-s.html
Burned valve pic in post #3.
All cylinders on my engine read 8 percent leak down except cylinder 3 the bad one. So if I can fix this by just removing the head in place I'll be ok...
-Will
Not many get into Cayenne engines so how common it is we will probably never know. In my experience with those that have worked with the Cayenne engines, as well as two sets of personal turbo heads, the guides wear considerably.
Sounds like you have experience doing a head job - can the bank 1 head be done in car/do you need any special tools?
-Will
-Will
You could possibly make your own set of cam timing tools (like the 928 crowd has done). I would venture to guess that they have timing marks on the cam you line up with the chain like a 928 and be spot on. Take lots of photos.
Received 1,140 Likes
The cam timing tools are a bar like device that fits across the camshafts and has notches that drop down onto a non-square protrusion on the camshafts - locking them to each other. There is also a pin that is used to lock the crankshaft at TDC for one of the cylinders (forget which one.) The tools aren't horribly expensive - I seem to recall seeing a kit of them for around $100. The crankshaft is locked, the cams rotated until they are timed together with the tool, and then the bolts holding the sprockets in place are tightened. That's a greatly simplified explanation. I'd suggest that anyone considering doing this spend the huge sum of $15 for a year's subscription to AllDataDIY - for their vehicle - and get actual Porsche instructions and specifications.
Luckily the tools seem to be readily available and only 100 dollars!
-Will
