Slight oil burning smell after brief feats of strength
Old 09-11-2018, 12:56 PM
thesteve
thesteve's Avatar
Default Slight oil burning smell after brief feats of strength
Is this normal?
I understand that oil consumption is to be expected, but if I smell something north of the tailpipe does that necessitate a leaking valve cover or worse?
I recently replaced all of the plugs and coils and didn't notice anything dirty in the area (although admittedly, I wasn't looking).
This is an 03 Turbo with 64,000 miles.
Old 09-11-2018, 01:21 PM
deilenberger
deilenberger's Avatar
Received 1,140 Likes on 758 Posts
The valve cover gaskets are known leak points when they get old enough - and it might drip down on the exhaust manifold - causing the smell.
If you intend to DIY - read https://rennlist.com/forums/cayenne-...cayenne-s.html - as a caution on what to avoid. Apparently, the valve cover on the passenger side is tight enough in location to other bobs and bits in the engine compartment - that it's possible to damage the camshaft-position-sensor-wheel on that side. As I noted in the referenced thread - this isn't the first time I've heard of this happening. Dunno how hard it would be to really clear that area out of obstructions - but given the alternative, the effort might be worthwhile.
Old 09-11-2018, 02:08 PM
Travis
Travis's Avatar
Our S had occasional oil burning smell off and on over the last few years until this year when it got noticeably worse.
I changed the valve cover and plug seals this year and presto, no more smell. It’s a chore, but take your time and it’s fine. Had more trouble on the driver side than the passenger side. Just have a low profile socket driver for the pain-in-the-*** bolts in the very rear.
Old 09-11-2018, 04:25 PM
thesteve
thesteve's Avatar
Darn. Any consequences of ignoring this for a while? I rarely gun it and it looks beautiful under my hood.
Old 09-11-2018, 08:01 PM
VulcanGrey
VulcanGrey's Avatar
You may also have some oil in the left intercooler from the crank case breather that feeds into that turbo pipe.
Disconnect the pipe and drain out any oil.
Old 09-12-2018, 12:11 PM
thesteve
thesteve's Avatar
Thanks. Dumb question, but has this been known to do really bad stuff to the intercooler? I'm guessing yes.
Old 09-12-2018, 12:19 PM
nodoors
nodoors's Avatar
Not really the intercooler. It can be degreased without too much effort. The real issue is that burning the excess oil will sludge your throttle body valve, the back of the valves, foul the plugs, and increase havoc on the o2 sensors and cats over time. It is best to empty that hose every oil change or better yet install a catch can.
Old 09-12-2018, 12:49 PM
Rossi
Rossi's Avatar
You did that all by yourself? Is there a good DIY?
Old 09-12-2018, 02:10 PM
Travis
Travis's Avatar
Yep, did it in the garage. Bank 1 one weekend, Bank 2 on the following weekend.
Pelican Parts has a good DIY: Valve Cover Gasket Replacement
On Renntech, there's a thread with some useful info as well: Valve cover gaskets replacement
and a thread I posted a while back: Valve cover gaskets, PIA!
Old 09-12-2018, 04:54 PM
deilenberger
If doing this job - please DO read my warning above and the linked thread. It's way easy to damage the camshaft doing this job..
Old 09-13-2018, 02:49 AM
Rossi
Rossi's Avatar
Thank you so much guys, I will go through the DIY and see if I could tackle this. I have 957 GTS, wondering how different will this be.
Old 09-14-2018, 03:11 AM
Rossi
Rossi's Avatar
Anyone successfully replaced valve cover gaskets on 957 V8 using the DIY above or can direct me.
Old 09-14-2018, 12:52 PM
Dilberto
Dilberto's Avatar
I'm betting the valve cover spark plug gaskets are saturating the hot plugs. Check 'em out....
Old 09-19-2018, 05:00 PM
Rossi
Rossi's Avatar
No one tackled this on 957?
Old 09-20-2018, 10:23 AM
jeff spahn
jeff spahn's Avatar
I don't know the underhood difference on a 955 vs a 957 for valve cover clearance but I did my 955. It was easy. The cam thing is no big deal. You just follow the pelican write up and you'll have no issues. Nothing should catch when you take the cover off. If stuck, don't pull. You'll have no problems
Quick Reply: Slight oil burning smell after brief feats of strength
