Nav Radio Faceplate is coming off
I am removing a Sirius Starmate attached at the faceplate of my nav radio and running into some problems with the faceplate trim coming apart from the back mounting piece. I had found a video showing how simple it is to remove this plastic piece. But in the video, it seemed to be one piece. What happened in my case was part of the silver painted trim came apart from the black plastic frame, that has the mounting pins. Now that I have the faceplate back on, the silver trim in front won't stay put on half of it. I don't see double-sided tape, so I'm assuming I need to use some variation of super glue.
Before I try anything, I'm hoping someone found a long lasting fix.
Use Shoe Goo. It takes over night to dry, but the bond is more or less permanent. I have used it for a couple different pieces of trim, including the trim piece right above the glove box, all to great success. Keep in mind that it does not compress easily, so a thin layer across the entire piece is best
Thanks. Do you know if it hardens completely, or does it keep some pliability? I am thinking, possibly, down the road of replacing the silver trim with carbon fiber. Just not anytime soon.
Remove the Silver piece from the plastic piece completely and make sure it's straight, Then adhere the 2 together using the Shoe Goo.or another Silicone or RTV type adhesive. When removing this trim piece, it's best to start at the top and do the side and bottom of the legs last. If you start at the bottom of the legs, they flex too much and will pop the aluminum from the plastic or if wood or CF can crack them in the middle of the leg.
I was at O'Reilly's and they didn't have Shoo Goo, so I found this other product called FiberFix Extreme that sets in 30 seconds, you can handle in 15 minutes, and cures fully in 24 hours. You only need one drop per inch, and it has a flexible bond on most surfaces, including metals and plastic. Retails $5.99
I have a new favorite glue: Loctite Go2 Glue -- it's a silane-based adhesive. Different chemistry than epoxies or superglues, and faster-setting than Shoe Goo and E6000. It's thick (almost like honey), but sets in about 30 mins, so you can reposition it and not have to wait forever to cure. It remains slightly flexible and is heat resistant. Use masking tape to avoid getting on surfaces you done want it on, but any squeezeout rubs off easily after the 30 minute set time.
I've repaired that NAV trim piece in the past with E6000 (and it's held fine), but if I were doing it again, I'd use Go2 Glue as it's easier to work with. I bought mine at Homie Depot. Also available on Amazon (where it gets very high reviews).
