Cayenne Transmission Control Unit Tune POLL
Let's keep this simple.
Please speak up if you are interested in a TCU tune for the Aisin TR-60sn 09d used in the 955 and 957 Cayenne. This is something that I will be pursuing for my project and like most things it's all about motivation for the developer.
High on the list of priorities will be:
*Raising or removing the TQ limit. Not such a big deal for the stock turbo guys with or without a flash as the TQ limits are already higher or close to what you can make on stock turbo's.
*Increasing the shift speed
*Giving full control in Tiptronic mode. Mainly the ability to hold a gear longer before a forced downshift.
* etc. - TBD
PLEASE, Only respond if you are SERIOUS and ready to pull the trigger TODAY.
PLEASE, state what you think the service is $worth$. (Give a number.) For the sake of this inquiry we will assume that the execution is satisfactory and produces RESULTS.
My Cayenne will be the test bed for development and if It can produce results in mine, the rest of ya'll will be fine.
It is very important that we keep in mind,
The Cayenne generally is not worth much. The goal is pricing somewhat concurrent with today's value, not what they cost new. That doesn't work. However please keep in mind that there is not a tune available as of now and cost/availability will be highly influenced on how many people are ready to commit with their wallets and not their mouths. This has been discussed before, however I am not that guy and this is not that thread. Please let us keep the references to that out of this. Be aware. The transmission is a good transmission. A strong transmission for the most part without major flaws. Your valve body needs to be straight before you dive into a tune.
This is just a poll, I am not a paid vendor and I am not soliciting a service.
Let's keep the responses simple. Are you interested? How much is it worth to you?
Thank you
* etc. - TBD
Thank you
Last edited by J'sWorld; 07-30-2018 at 11:04 PM. Reason: Removed references to any finance. It's irrelavent at this time.
I am definitely interested in improving the way the transmission functions. I hate the 2nd gear start that happens unless I'm in sport mode and the transmission is always in 1 gear too high with engine RPMs at 1,500-1,700 most of the time, which makes it lug until I make it upshift with the pedal or the Tip - button. The default behavior in sport mode should select gears that keep the motor spinning at around 2,000 RPM and hold gears longer unless no throttle is being applied - i.e. don't upshift unless the RPMs will be at 2,000 after the shift.
The automatic mode is so annoying to me, being a manual transmission guy, that I'm getting ready to install Mercedes paddles on my wheel and drive it in manual mode all the time.
J, will what you're talking about correct these behaviors?
What's it worth to me, maybe $500... more than that and I'll mount the paddles.
The Softronic tune on my 2009 CTTS not only creates over 600 HP but it also keeps the revs up considerably. The engine never drops below 3k rpms unless coming to a stop. It is really so good that I generally leave it in automatic when I am on twisty mountain roads. My hat is off to Scott and how he transformed my car. I wish under normal conditions it could shift this way, but as it is triggered by turning off PSM, one has to compromise. I do, however, like being able to drive around in our insane Seattle traffic with the normal tune, so I am happy to have the normal 550hp tractability. Having over 600hp in rush hour traffic with the revs constantly up can present challenges.
Cheers,
TomF
Cheers,
TomF
Cheers,
TomF
Cheers,
TomF
Thanks for the responses guys! Please, please re-read my post so I don't have to be what the smowflakes consider ugly.
1. I find PSM off to be a bit too agressive. Especially in first gear. I feel like an attention ***** in traffic with PSM off in first. Anybody share that?
2. @ Tom F. - I think that is normal psm off behavior. Remember that as you increase power and TQ the stall of the converter will increase as well. PSM off keeps the converter unlocked quite a bit more.
3. Scott can't tune my Cayenne.
4. Scott has had more than enough time to address his involvement/progress in a TCU tune. There is nothing to know. Period. I ask that we do not make references to Softronics please.
5. I will throw ya'll a bone. If you cut the output shaft speed sensor signal from reaching the TCU, protocol is to use the abs signal as default and eliminate the shift adapt program. I have not had a chance to test this yet but it is a simple as cutting one wire at the trans harness. PM me for the tech documents.
PSM off simply lets the TCU know to use a different shift program or "MAP". The ECU can be made to lie to the TCU about how much TQ the engine is making. Theoreticly, at some point the trans would see too much slippage by comparing input and output shaft speeds against the gear you are in and interveen. Unless, there is no output shaft speed signal..........hmmm.
$500
Psm off is indeed atrention ***** for me as it's very loud. When I do psm off, I always shift early from 1 to 2 manually.
I'd like to have something in between psm off and normal.
Sounds like we are starting to get a list of wants together. If you can get an e-tune Tcu flash for the rs7 for around $200, I don't see why @ $500 somebody wouldn't take this.
Here is one for the C6 Audi RS5 transmission ($450). The RS6 ran ME7.1.1 Motronic, same version as ours but it had a crappy ZF 5HP24 tranmission, not an Aisan. Probably a Bosch or Seimens TCU.
https://store.034motorsport.com/c5-a...e-upgrade.html
I would think that whoever could code the TCM for the Cayenne could also make money off the Touareg guys. I've seen threads on the Touareg forum where some of the VW guys swapped for a Cayenne TCM as they felt it shifted better.
