Scrubbing bubbles
Scrubbing bubbles
Got the idea from my friends at fchat. Spray with scrubbing bubbles in the aerosol can and LIGHTLY SPRAY engine bay with a rinse of water. Finish off with a spray of griots engine bay dressing. Next up is the Carrera S. Then the 360!
I wouldn't recommend doing this. These cleaners have strong chemicals. With a light application and a one time use, you're probably fine. With repeated use, I'd expect after a few years you would start having issues with the wiring harnesses starting to deteriorate.
At least it's safer than steam cleaning or pressure washing in there. Sure looks clean and shiny.
I have a very similar garage. '06 TTS, Carrera 4 and a Cali 30.I need to try this on the pig when I get her back from the shop.
