Possible AC Water Leak?
2006 Cayenne S
Had the air on today, turned a corner pretty fast, and water splashed on my right foot (gas pedal side), Any ideas where it's coming from and how to fix this?
Received 1,140 Likes
You may want to go look at a few threads in the DIY forum.. and search a bit here (the problem has been extensively covered)
For the HVAC drain see: https://rennlist.com/forums/cayenne-...l#post14310830 (I think I'll add that to the DIY subforum when I have a chance.. mebbe with some photos..)
Cowl drains are also an issue - this is for a later model - but the technique/problem is the same: https://rennlist.com/forums/cayenne-...clean-out.html
Then you may want to read up on what problems the water can cause - it happens to many Cayennes - when you start getting lots of odd electrical problems: https://rennlist.com/forums/cayenne-...-moisture.html
Welcome to the forum!
Thanks for the link to the HVAC write up. I hadn't seen that one before. I pulled it apart last night, and was surprised that water didn't come out of it. The flapper was pretty full of gunk, so I cleaned it and the drain tube.
Hopefully that was not letting the water drain fast enough, and cleaning it fixed the issue. We'll see.
