What to do with used rotors?
I changed the front and rear rotors on my '06 CTTS. The existing rotors had about 85k miles on them and they are still within the wear limit, but there are serious grooves on them.
Any suggestions on what to do with these rotors?
I always do the latter, as long as the thickness is in spec.
I let my scrap pile up, once or twice a year when I am tired of looking at it, I carry it to the end of the driveway, and it is usually gone within four hours. If it is not, I post on Craigslist for free, then it is gone within an hour.
Choose one or more of the following options:
1. Practice your discus throwing?
2. Sharpen the edges, then add an old wheel bearing and a long handle to create the world's largest pizza cutter?
3. Yard decoration "rural Kentucky chic" style?
4. Put them in a box with other old car parts and take to the county recyling yard when the box is full.
I usually go with option 4.
Where can you get your rotors turned nowadays? I need to put in new front pads and the rotors look good with a small lip. I'd like to verify if the stories about turned rotors warping and causing other trouble are true.
