What Did You Do To (or With) Your Cayenne Today ?
#197
Installed my new wheels and tires.
Rinnspeed reps (22x10), ET50 with 14mm spacers up front and 20mm rear. Tires are 285/35/22 Continental DWS06.
I have never been a big fan of black wheels but they are everywhere now so I thought I would give them a try and I do like how it looks. Definitely racier/more aggressive.
#198
Had the faintest whine - thought it could be cardan shaft bearing needing repacked, transfer case, rear or front diff - checked rear diff oil just by using a syringe. None came out of the fill plug when I opened it. Oil has been changed pretty recently by the look of things, so I thought Id just top it off with some nulon g70 diff treatment. Needed 100ml on top of the oil Id sampled..so the rear diff was low. Its now quiet as a mouse, that was the source of the noise,
#199
#202
Vacuumed around it - LOL
#203
One of my auxiliary power outlets in the cargo area was missing the cap so I replaced it with an extra USB charging port I had lying around.
Found that a 5lb fire extinguisher fits perfectly where the the self leveling tank would go if so optioned.
Tidied up the engine bay and replaced some missing trim piece fasteners.
#207
Tried to get vcds lite working with a really old I think Durametric cable clone - couldn’t so gave up on the idea. Emailed foxwell to ask them to allow coding of the byte/bit to enable auto dim light feature - got a response they’ll pass it on to engineering. Washed the car. 2 hours of happiness....
#208
Met up with a fellow Rennlister and completed my turbo cluster swap- he also got auto headlights activated (THANK GOD), cleared the headlight error due to the cluster, turned off the TPMS, and turned on the coming home/comfort lighting.
A good day indeed!
A good day indeed!
