I want to return my Cayenne S!!!!
I have tried calling PCNA with respect to an isuue with this car and I have yet to receive any resolve at this point and I just want to get my money back. MY main issue is the KEY FOB. It's so retarded that trying to unlock all doors without in a millisecond if I don't press 2nd time it locks up and gotta wait til it resets itself. It's raining in San Francisco and man I hate getting wet. Is there a TSB for this Key Fob? Other then that the car simply amazes me with respect to driving it that I almost forgot I have a 996 but this Key Fob is killing my fun. Am I **** : )? Hope everyone has a great weekend and happiest of holidays!!!!!!! Mike
P.S.-I was joking-hope it litens your day : ).
Snow in the Sierras??
You know I haven't figured out this one yet either. Only door I can get into is the driver door when I am on the other side of the car I can't seem to get the doors unlocked with the remote.
I really would like someone to give me a step by step on how to reprogram the thing to open all 4 doors with one press each time as opposed to the double press which does not seem to be working. Thanks for your reply and help. Cheers.
Use the toggle switch on the end of the windshield wiper stalk and the selector button on the underside of that stalk. In the info display (between speedo and tach) toggle to Main Menu and select. Toggle to Settings and select, then Comfort and select, then Door Opening and Select, then Doors and select. This is where you select the All option to have all doors lock or unlock at the same time.
GMAustin, thanks just did it and it works.
Now all I need to know is how to set the programable memory seats to more than memory position. It seems mine learned where I had my seat set and used to move the seat to my position and the steering wheel also into my position when I put the key in but now the wheel does not move up and out of my way when I pull the key out like it used to and when I put the key in does not move into position like it used to. So step by step instructions on that would be very much appreciated. Cheers and thanks again for the help.
The main thing you are missing is once you have selected that choice you must turn the ignition off exit the car and then lock it using the remote. Then it will remember that choice with that key...
