P1341 code - 2001 Boxster S
Another potential cause it seems is if the oil pumps are installed incorrectly.
Lastly, could possibly a blown AOS cover the camshaft next to to it with so much smoke & oil to foul the camshaft sensor into giving cam deviations that are out of spec?
That is unusual. The Solenoid is usually the first part of the Variocam System to fail(electrically). Fortunately it is easy to test.
A failed Actuator produces a rough idle.A failed solenoid does not.The Actuator can be dismantled to observe the cause of failure.
It may be wise to do this? Like any hydraulic device the issues are usually seal failure,dirt/blockage or scoring/wear.
