Urgent Help Needed PLEASE
This is a super easy replacement. I did one the first time in under three hours never having worked on a boxter before (lots of 928 time). Don't forget to vent the system though or you'll throw an overheat light.
Once you remove the hoses then removing the motor mount is a breeze. Lower the motor slightly remove the motor mount and now you can get at all the wp bolts very easily. You can torque them all with a torque wrench.
Then bolt up the new mm and you hopefully never have to replace the wp and mm ever again
