Replacement springs for 986 with standard suspension
From some notes I made at the time:
Blue and yellow at the bottom and a red/orange dot at the top. Apparently in about 2003 the colours for the top line changed - orange is now the new white. This top coloured dot determines whether you need a 3mm or 6mm compensation plate (996 343 511 00 or 01) - essentially the rubber plate between the top of the spring and the support plate.
