Brake Calipers
Brake Calipers
Hi all - I am new to the Boxster world and could use some advice. I have a 2002 Boxster. I want to change my calipers to red, like would come on an "S". If I buy a set of used S calipers will they fit on my base Boxster? Or will I need additional components?
Thanks.
David Preston
Thanks.
David Preston
In a word, no, they are not a direct bolt on
From JFP in PA on another forum:
"The front S caliper and rotors are a bolt on swap; the rears no so much.
The S cars used different axles and hub carriers, so the emergency brakes from a base car will not work. To convert the rear, you need the S hub carriers and e brake set up as well as the calipers and rotors."
Good conclusion
Also, while this is not a bad forum, it is not very active.
Check out 986forum.com. It is far and away the best 986 forum, around
Just be sure to introduce yourself and include pics of your car or be ready for some ribbing
Also, be sure to do a search before posting questions. Often you can find what you are looking for
