Bent Radiator Fins - Reduced Cooling or Just Eyesore?
Does this radiator need to be replaced (and does the bumper have to come off for this job)? Or just repaired with a screwdriver or one of those "comb" tools to pick out the folded/squished fins and make them stand proud again (so they are not blocking air flow) and re-paint the area in flat black? I'm worried these damaged areas will create hot spots, negating the benefit of even having the 3rd radiator. I don't think any of the coils in the core are damaged (nothing leaking but I suppose there could be some blockage or restriction but as far as I can tell the damage is only to the very front edge of fins, I'm just not sure it's cosmetic only). And yes, now I know they sell mesh grills that can help prevent this.
if it was mine i would not take the risk of doing more damage .i do not see a cooling issue until alot more are blunted. hit it with some black paint if it bothers you that much and fugetaboutit
If the radiator did need to be replaced the front bumper cover would have to come off. It takes an experienced tech just a few minutes to remove the thing.
Like extanker succinctly put it: fugetaboutit.
Thanks for your responses. That's 2 votes for "do nothing" (or possibly spray some rattle can paint and move on).
Assuming my dealership was willing to somehow replace this under warranty, or my auto insurance would replace it under a claim (again, just speaking hypothetically), should I go ahead and authorize its replacement for maximum cooling performance (and because I'll always know it's "damaged" even if I paint over it), or is there too much risk for collateral damage or panel gaps not lining up once the bumper is removed? (It will never be the same as factory fit and finish, etc.)
And your car insurance would almost certainly refuse to pay for the replacement as the dealer/shop the insurance company would have you take the car would dismiss that damage as inconsequential.
The bumper can come off to if necessary to among other things access the radiators if and when the time comes to replace one or more. The bumper cover can come off to allow the trash that collects in the radiator ducts, and between the condenser and the radiator, to be removed. In all cases the bumper cover should go back on the car and its before and after appearance indistinguishable.
So let me join the chorus: fugetaboutit.
