V8 Conversion
good move getting rid of that first ls motor...i had no faith in it. iirc crank pulley bolt is a one use only .i trust the new and improved ls came with starter,alt and intake and wiring harness/coils
Had no idea about the bolt. The engine didn't come with anything, but I have to replace all the components with the ones from F body Camaro anyways. I alreay have an LS1 intake and porsche alternator, but I'll have to get the harness and throttle body. I haven't done my research, but I think I can use the coils that came with the engine.
i wish you luck but imho you are making so many costly mistakes that are going to require money/time/more money to fix. are you going to use GM engine management eg FI/spark timing ? will the po alt work with the same number of grooves in the drive belt....i cant fathom it lining up without fabrication and that type of work aint in no how to work on an ls motor 101 book.will this car be driven on the street or have to pass any state MV inspection ?
I'm going to use an LS1 stand-alone harness and ECU with a proper tune to run the enginge. I will also have a Porsche ECU for the instrument cluster, so I will tap a Porsche water temperature sensor in the passenger head, and run both oil pressure sensors on a remote line. The only thing I may have trouble with is the tach. On the new GM engines you can just tap into the crank position sensor and its pretty much plug and play, however, my engine is older so it uses a 24T reluctor wheel. I will have to change the output signal to match.
As for the alternator, I havent really looked into it at all because it doesnt matter at the point where I am in the build. All I know is that there is room for it, and thats all that matters. Sure, I may have to buy a GM alternator to match the harmonic balancer pulley, but thats like 50 bucks.... Making an adaptor plate for it doesn't bother me either.
Yes this car will be driven on the street and track , so I will have to pass Ontario safety.
Good to know . I believe I should be fine with the stock setup, but I will double check. I haven't read anything about this from people who completed the swap.
Hey, its an S. I'm actually getting the kit from them. Should be here within a couple weeks hopefully. The problem with Renegade is lack of instructions, I'm left to do 90% of the research on my own. It doesn't help that I'm using a pre 2006 5.3L engine.
To be honest Renegade were not much help with part selection. They just said they only do conversions on crate motors and there are 100s of ways to build the car. They dont offer much instructions "because every build is different", which doesn't make too much sense to me. I get most of my information from people on forums. I'm not trying to knock Renegade because they do pick up the phone when you have questions, and Steve there is a great guy, but I wish there was a more detailed conversion guide for the price.
As for my truck motor, its not that much trouble. Its just my frist time tearing apart an engine, so there are many things that I don't know and have to research. To me this is not a big deal, and I actually quite like it. I may make some mistakes along the way, but I will learn from them. The engine cost me under $1000 USD and I will have to spend another $800 or so to retrofit it with LS1 parts. An LS3 crate engine with the harnes and ECU costs about $8000. And you still have to swap out the oil pan and harmonic balancer to make it fit.
