Dead battery/can't open trunk issue
Anyone in the Bay Area , near walnut creek able to help with this problem? Can't open front trunk to charge or replac battery. Trying to avoid having cat towed and paying big bucks for something I should be able to fix myself. Not very handy but I did try hooking up battery charger to red trunk fuse but that did not work. Please help. Thanks
You have an emergency release cable (mine was on the passenger side) somewhere in the wheel well. It's a small diameter wire cable with a loop. Find it and you will be in good shape. Then for next time- route the cable and put the loop behind the tow bar access cover.
The location of the release cable depends on the model year. What year is this?
Scott- you may be able to google this faster than we can respond; some model years take a little more digging to get to the cable than others, but if you can get the mechanical release, you can pop the frunk and charge/change the battery.
Yay, #4 option worked, but not by using a charger. Had an old battery in the garage that apparently had enough juice to make it work. Cable to fuse, cable to door hinge and two cables to old battery in garage and it worked. Thanks for everyone's help. Now, new battery from dealer or a over the counter battery from autozone? Opinions?
Well....
IIRC Consumer Reports rated Walmart batteries highly. They have a 986 fitment - I checked a while back when I was in buying Mobil 1 for my car. Walnut Creek shouldn't be tough on a battery: no freezing winters or 100*+ summers.
See https://rennlist.com/forums/928-foru...nterstate.html
Of course it works fine, unlike tires you can be a cheapskate in the battery department and slide. There are only a few battery makers, these private label units are most likely Exide anyway. I'm not sure if Interstate private labels but it's a good bet they do and keep it quiet lest they cannibalize their money making logo. I still have the Porsche battery but I would get a megatron when it goes. Even Kodak made a "general purpose" orthochromatic film near the end, it was straight up TMat-G in a less pretty box.
I worked for three major product manufacturers one of which did mostly private label. They don't change established manufacturing parameters, if anything, a run close to being out of spec but going out for sale anyhow might end up with the "off brand" stamp and even that really was not common.
Here's my thread on re-routing the emergency release cable, to avoid future problems.
https://rennlist.com/forums/996-foru...e-measure.html
As stated above, there are a very few battery manufacturers. Search the threads here... many have been very happy with non-OEM batteries.
