Missing part on transmission. HELP
Hi all, got a 99 boxster that has shifting problem. Got the car towed to my friends shop and found something missing (dropped somewhere) on the transmission. The problem I am having is the car wont shift into 1st or 2nd. All other gears seems funny as well. My friends believes there should be a bolt there and it should connect/hold onto the shifter linkage inside the transmission.
Picture at the bottom. This is the right side btw. I believe it is number 14 on the parts diagram, but dealer said that is for the reverse. And the parts guy said he thinks it is #16. Problem is either parts is not stocked inside the country and it will take 2 weeks to bring it in, so I hope to get it right the first time.
https://docs.google.com/file/d/0B4Ah...NFWXZHYkU/edit
https://docs.google.com/file/d/0B4Ah...V2Z1hoOEU/edit
#14. Some sort of transmission fulcrum pin (not sure what they're really called). Almost all of them were made of Aluminum and are prone to failure (espically with track use).
Link to some pics I posted in another thread: https://rennlist.com/forums/boxster-...ml#post8748573
