Boxster & Boxster S (986) Forum 1996-2004
Best HP and TQ from a 3.2L 986 Boxster S ?
Old 07-23-2011, 09:13 PM
ltusler
ltusler's Avatar
Onefast, was the AFR probe not connected?
Old 07-23-2011, 09:54 PM
onefastviking
onefastviking's Avatar
Correct. It kept blowing it out of the exhaust. It still could be improved upon which I plan on still doing and will show a new dyno when completed.
Old 07-25-2011, 02:21 PM
mglobe
The Penguin King
mglobe's Avatar
Originally Posted by onefastviking
Yes, I am guessing a 3.4L like that should be around 290+ hp
Post the dyno results when you get it.
You need to get 290hp out of my 3.4. ...legally of course.
Old 07-25-2011, 03:47 PM
onefastviking
Tell me you are just going to run NASA and not the Spec 996, and write the check, and you'll have 290rwhp. You know I know what it takes to do it.
Old 07-26-2011, 08:51 AM
mglobe
The Penguin King
mglobe's Avatar
True
Old 07-26-2011, 05:09 PM
abqautoxer
abqautoxer's Avatar
One thing about a dynojet to eliminate the feared correction (SAE) is to use the STD correction factory instead and set smoothing to 3. I know some people feel thats much more accurate.
Not a Boxster but that correction/smoothing is what more people tend to trust.
Old 07-26-2011, 05:49 PM
onefastviking
Actually, my concern on the hp is for rules compliance in NASA GTS class, so I use what the want me to.
As for the smoothing factor, actually the higher the smoothing factor the more accurate the readings will be. The higher smoothing factor will limit the peaks which are usually incorrect spikes in the dyno graph.
Either way, the dyno is just a tool to use to know whether I improved or not, all dyno's will vary some depending on dyno conditions.
Old 07-26-2011, 06:02 PM
abqautoxer
abqautoxer's Avatar
True I forgot NASA likes SAE correction, but they do allow smoothing set to which ever. 5 looks better but hides stuff IMO. I'm planning to get my bone stock 02S dyno'd soon but I don't know if that will be a good "before" for you or not.
Old 07-26-2011, 06:32 PM
onefastviking
NASA GTS wants a smoothing factor of 4, I'm not sure what the others (NASA ST) require.
It would be interesting to see your bone stock Box S, please post it on here when you get a chance to get it done.
I will guess it's around 220-225 RWHP, but that is just a WAG.
Old 09-12-2012, 11:18 AM
onefastviking
Ok, looks like I am now over 270 RWHP, and that is while turning a big 295 wheel/tire combo. Still making power out of a little old 3.2 liter Boxster motor. I wonder what I could do with some cams, head work, and a little more displacement ???
Has anyone tried more displacement out of the 3.2 liter block/cases ???
Old 12-03-2014, 07:43 PM
Pike1181
2nd Gear
Pike1181's Avatar
I did 2 pulls on my '06 3.2L Boxster S with a DynoJet last year and got 287 crank and 245 @ the wheel.
That was with a FVD Exhaust and GMS Headers w/ 200 Cell Racing Cats.
Since then I've upgraded to catless racing headers, 911 throttle body, 911 Plenum, and tune by ECU Tuning Group.
I'll be putting it on the DynoJet again in February 2015 to check my gains.
What do y'all think about those numbers so far?
Quick Reply: Best HP and TQ from a 3.2L 986 Boxster S ?
