Water leaking through top
8th Gear
I have a 01' Boxter that has been taking water behind the passenger seat on the bottom and in the area above where the control arms are for the top when it rains.
I am told that there are drains in the area back there which may be clogged with debris. Where may i locate these drains?
Thanks in advance,
Mike
Thanks in advance,
Mike
Thanks in advance,
Mike
Thanks in advance,
Mike
Open front trunk. Remove battery cover. Remove the two plastic covers/panels on either side. I think you'll need a Torx bit (maybe even a security bit -- has a hole in the center of the bit to clear a pip in the center of the Torx screw's head) to remove the screws that hold the panels down secure.
(As an aside: just buy a Torx set of bits with the security feature.)
Be careful with the styrofoam-like material. Do not poke a hole in it or break it cause water will leak through the hole or the crack.
After you remove the trash avoid parking under trees and around bushes/plants that shed plant trash on cars.
Sincerely,
Macster.
Hi,
How do you simply change an air injector Valve on a 1999 Porsche Boxster? I can see it off the main hose of the air pump but its under the intake manifold, I don't see an easy way to change this valve except maybe remove the alternator.
__________________________________________________
Porsche Parts
Porsche Parts
