Racing Boxster's? Where are you guys?
My Boxilla
Here's my ride. Thanks to Christian (Verbotn) on RL, I got a great deal on PSS9's and GT3 seats. I'm thinking he needs to move to a Cup Car and give me a similar deal on his "mini-GT3"
My other mods include Pagid yellow pads, GT3 brake ducts, GT3 master cylinder, ss brake lines,separate set of wheels/R compound tires, B&M short shift. Brey Krause rollover bar, 6 point harness, Sports Exhaust. I do one DE/month on average along with the occasional autocross.
BTW, I usually trailer this to the events. My back can't take more than an hour street driving.
Currently building 2 Box S models, both will be stock 3.2 motors. Well....... kinda stock........ ok, maybe not stock....... ok, not at all stock !
The rest will be pretty standard upgraded stuff, complete custom cages like I always do,new susp. with monoballs, big functional wings too, etc, etc.
I'll get some pictures to follow later.
Hey how did you set up the top adjuster for the Motons with the rear MODE's ? I am thinking of just cutting a hole in the clamshell on mine for easy access. Then cover it with a sticker or tape for looks.
With the Mode plates / Moton's in the back, the top of the adjuster BARELY clears the sheet metal in the back, and can be reached from inside the car. It's tight. It's also pretty easy to remove the hard top (at least with a factory top) lift up the clamshell, and reach in there. Although, if you put some big holes in things, the car gets lighter!
You guys seem to know so much about it, mind if I ask you a question? What do you recomend I improve in my wife's 03S tip with factory M030 to make it more track friendly. I would like to tighten the car a lot, stiffen the suspension a bit, get some air into the engine and change the exhaust while I am at it. Lets say I wanna spend $5K. What does that get me?
It also has PSM, 18" hollow Turbo rims. I have changed brake fluid to racing blue, but brakes still feel like shiite.
P.S. Please dont say DE. I've done quite a few. I dont wanna race, just make the car feel more planted and alive.
Thanks fellows.
Thanks fellows.
Don't bother trying to make more power, it's a waste of time buying intakes / exhausts for these cars unless it's REALLY modified. The exhausts also tend to be incredibly, annoyingly headache inducing on top of not giving you more power.
For brakes, the original brakes are the best thing for the street. I'd consider stainless lines to improve feel a bit, but that's all.
I started building my car with the intent of it being a Spec Boxster car, but nobody in the Pacific Northwest seemed interested in the class, so I got out of control. I love the Spec Boxster idea, but it just wasn't going to be fun racing with myself, so I built something faster (and, unfortunately, a lot more expensive...that wasn't the original idea, again, but I digress).
Thanks for the advice.
Actually, you guys PPI'd this car a few months ago. A lady from the states drove up in a dark blue Boxster S with 100K miles on it. You didn't find much wrong with it (except for the rear pads and sway bar bushings) so I bought it sight unseen and had it shipped. Thanks. Love the car. Now I wanna start building a Gocartster.
Will H&R sway bars be a significant improvement over OEM M030 bars that are already stiffer than regular ones?
P.S. Changed the sway bar bushings, but it didn't fix rear end clunk over bumps. Someone recomended I change the control arms. What do you think?
I like the H&R bars. They have a bit more rate than the M030 bars, and pair really well with the Bilstein kit.
On your clunk issue, it's possible that several other things could be causing this problem (sway bar bushes being a common problem on higher mileage for creaking, etc.). These include, but are not limited to: Sway bar links, shock mounts, control arms, or loose components. I'd probably try the sway bar links first, if there isn't anything else obvious.
Thanks fellows.
Thanks fellows.
I have an S and do my own work but once you start it becomes addictive and I'm having trouble knowing when to stop, so it's a work in progress.
[youtube]kSaz17vWKTk[/youtube]
Picked up a 98 Boxster here in Victoria for the track. At this point have removed most everything not needed for the track. Presently down over 600 lbs. Have autocrossed it last summer and now needs to have suspension and cage work done. Not a pretty car but very functional and affordable.
Thinking that I would like to remove the power steering system which would also allow me to simplify the engine drive system substantially. Any advice on this. New to forum. will send pictures when able
I'll play.
My car is a 99 Spec Box. I don't race but I'm considering it. The car is an absolute blast to drive.
Sounds like a familiar formula!
