Dual-use pad compound preferrences
I just picked up my first Boxster. It will need new rotors and pads soon, and I'm trying to figure out which pads I should go with. The car is my daily driver and will see several track days every year. Ideally I would buy pads that are suitable for the street and track, although realize this my not be the fastest track setup. The car will have high-performance street tires on it and OEM suspension. What pads should I be considering? I've used Pagid Sport Blues in the past with good success, although think I need something with better fade resistance. I've also used Ferodo DS2500s which hold up to heat better, but am still not sure that compound will resist heat well enough for track usage. Am I just out of my mind thinking I can use one pad for both purposes? I realize there are compromises to be made.
I'm particularly interested in Hawk pads, as I get a significant discount on those. Which compound should I look for? Any words of wisdom are greatly appreciated.
Spec Boxster guys were recommending pagid yellows on the front and blacks on the back. I don't really see a problem with using these on the street either ... Seems fine to me so far in my otherwise stock boxster.
I use Pagid Yellows, the RS29's all around. No squeals here and great stopping power and less heat then previous stock compunds of Pagid I used.
The advice I was given is that they might squeal on the street, but once you have done a track event, they will be silent for around 5 to 6 weeks. Then the squeals may come back. Another track day, and silence again for 5 to 6 weeks. Repeat
Former Vendor
Yellow or Yellows/Blacks - Y/B for track use with R compounds and *the desire for MORE rear bias*
I have BOTH in stock.....volcano has created a very short supply.
I have them all read to go -
