Changing spark plugs, found a torn CV boot
#32
#33
Lots of gloves and paper towel. I went through 2 boxes of gloves from CVS and 2 rolls of paper towel.
Once you remove the end cap and boots, the old grease is everywhere. A workbench and vise is highly recommended. I found I needed some odd size metric sockets, got a special ball joint tool from Harbor Freight for $16 and I had to rent a torgue wrench from Autozone as mine only went to 75 lbs.
Good luck!!
Good luck!!
#35
All done! did the Transmission fluid, rear brake pads, and bled the brakes at the same time. about 6 hours from arrival at my friends garage to departure. Everything went great. The shifting and brakes feel great.
I will do my front brake pads when they come in and then I will be ready for my first DE next month. wahoo!
