Sat Nav
7th Gear
Sat Nav
Has anyone fitted a 3rd party SatNav system to their Boxster? If so - which system. I am interested in fitting one as I do not have PCM but I DON'T want to devalue the car by having holes put in the beautiful trim etc.
I have seen a Blaupunkt unit that (supposedly) fits in one of the DIN slots and requires no other equipment to be installed. Has anyone had any experience of this?
Something like the Blaupunkt would be ideal as I could remove the little storage slot and put it its place...then remove the unit and replace the storage slot at trade in time...
Comments appreciated.
I've done it to my 996 (the blaupunkt unit)
Pretty simple install if you know how to DIY. The only minor difficulties are hooking up to the reverse signal (I did it through the fuse box) and the satellite antenna.
No holes or anything but the GPS antenna does have adhesive on it...
JM
JM
7th Gear
Originally posted by Jean-Marc:
<STRONG>I've done it to my 996 (the blaupunkt unit)
JM</STRONG>
JM</STRONG>
Oh yes....I just went on vacation with my wife and after two weeks of her map-reading I decided that SatNav significantly less expsensive than divorce....!
I replaced the whole unit (not sure I would do it differently..) and also installed a Blaunpunkt 5 CD changer where the CD console holder was. I kept all the original equipment so that I can put it back in place when I sell the car if the buyer isn't prepared to pay the extra money for it....
JM
JM
5th Gear
Too much work, and not portable. I simply use the Garmin GPS, the model made for vehicle use. Do not know if it has map cartridges available for Britain though.
Art
Art
Have to concur with above (Garmin) suggestion. The Garmin EMAP makes a good low end addition --the size of a cell phone, decent display, about $250 US. On the high end is the Garmin Street Pilot 3 -- about the size of....hmmmm...two Big Macs (side by side:-), excellent color screen, lots of routing features. Both of them can accept detailed
metro info (UK and most of Europe is avail) and with a big memory card (like a flash card) you can load most of Europe into either device. Both are completely self contained, portable, and reasonably accurate (the SP3 uses the new WAAS sat info---3(?) meter accuracy).I've used both and I never go anywhere without the EMAP.
