*my two-cents*
Originally Posted by Dave Howerdel
Semantics. Production costs, inventory stock, all marking related issues. I will refrain from further speculation to avoid upsetting any purists who can't come to terms with my opinions on Porsche's corporate identity change.
I do pretty much agree with the rest of your latest post though.
Gary
Originally Posted by Gary Gaukler
The pad material is uniform. The minimum pad thickness is specified by Porsche. There is a warning light in the dash that lights up a little bit before the pads are worn to minimum thickness. If you decide to ignore this, then you will damage your rotors. That's hardly Porsche's fault though.
Originally Posted by 85percent
what about the fact that the sensors stopped working and I had no idea the breaks were being worn down? another genius design by the retards.
And how do you explain going through 3 or 4 sets of tires in 2 years?
bye-bye 85 percent.. enjoy your next car.. But, to be fair, if it is something other than a known appliance (read - jap/korean car) please report back and let us know how flawless it was
I have never ever ever ever ever seen or even heard about a wire that gets cut when the brakes wear ( theres 8 wires to so chanccs of all 8 not getting cut .............no) not getting cut abd setting the brake wear light. your a troll dude probaly a 14 yr old with a boxster hot wheel please continue posting though cuz you provide hours of amusment
Originally Posted by J-RAD
You must drive around with one foot on the gas and one foot on the brake.
Sorry for digressing - just trying to lighten the mood
Originally Posted by akif
Aah, a reference to Sammy and my freeway anthem.
I'm not specifically looking at the break issue (even though I did end up spending $1987.00 two days ago for THAT and the 02 sensor), I'm talking about every one of these problems including the blown engine and everything else.. I'm just wondering why Porsche seemed to half-*** these Boxsters and then not stand behind their mistake?
by the way, I'm 24..
Sorry to hear of your misfortune. That doesn't sound very good.
Just curious... why did your rotors fail twice?
And how many miles did you get on one set of tires? Do you drive 40,000 miles per year??
the reason why the engine replacement was a little more expensive is because its a Boxster S engine with a reprogrammed ECU..
i just reaaaally reaaaally wish I would have spent an extra $5000 when I bought the car and went with an 02 or an 03... I don't think I would have been running into nearly as many problems..
Theres no fuse its a hard wired deal that system has been the same for 25 years and ive never heard of one failure
if you drive enough miles to wear out 2 sets of brakes maybe everything else was just old and worn out too. Or trhe PO didnt care for the car thats not porsche fault
Well here's the result, regardless of whether this hasn't happened in a thousand years..
My break pads wore down, enough to ruin the rotors. I didn't see any warning light AT ALL. Maybe my "bulletproof boxster" has a ***** in its' armor? no no that isn't possible, it couldnt be another Porsche malfunction..
