replacing battery on boxster
Sorry if this post has been put up before, I couldn't find specific answers for what I was looking for.
I have an '02 Boxster S with the original battery. I want to replace it and was told by the dealership they want $150 labor in addition to the part. The gave me a line about having to reprogram some "things" on the car after the battery was replaced. Seemed a little odd to me, and they couldn't clarify when I asked.
Is this for real, or can I just pop in a new battery myself at the house?
Thanks for the help.
Cory
Cory
Hah! That's a good one. A really good one. What's their labor rate, $500/hr??? In a recent thread I posted, I was having trouble starting my car - turned out to be the battery. I just started it last night with a Subaru Forrester battery (doesn't come close to fitting, btw).
Give me $149 and I'll reprogram it for you.
You also should run the windows up and down a few times to reset the limit stops.
What stealer is this?
http://www.renntech.org/forums/index.php?showtopic=2950
Go to Walmart and pick up an Everstart (made by Exide so it's a top notch battery) with the same cold cranking amps and same size base and height and you will be golden for several years at about $50. As mentioned before, you just need the radio code.
Edit: I forgot to mention the ventilation tube. You need to buy a battery with the connection for the ventilation tube that is used in the Boxster.
The only time a dealer has to do anything when the battery is disconnected is if you disconnect the battery and pull one of the seats out before waiting 30 minutes. Then you get the airbag light and it won't go off without the dealer plugging it in to his computer.
I figured that to be the case. I am in the Los Angeles area, guess I will just go pick one up myself. They wasnted $130 for the battery and $150 labor, or vice versa...but you get the point.
Thanks for all the input. If I do reset need to reset the window limits, how is that done? Also I read on a couple other posts about turning the key on but not starting the car to set the fuel mixture, or something to that nature???
Once again, thanks for patience with me, I am usually a diy type of guy, just new to this car...Just got it about a month ago.
The turn the ignition on for X seconds without starting the car, then turning it off, really does not need to be done. Our local group has never done it after a battery has been reconnected and I have never seen a mechanic do it. I forget the purpose of doing this without looking it up. I think it is to set the e-gas.
But I can do it for you for $148.....
Originally Posted by arenared
To set window limits, just power them all the way down, then all the way back up.
If you are being cool you can use jump leads to connect the new battery in parallel to the old one and then swap out the old one.
This means the car never knows that the battery has been changed and nothing needs to be reset.
I won't speculate how many Porsche centres do this and still charge you 150$.
P.S. to reset the power windows put them up as far as they go and then press the up switch again to store the position in the memory.
I have a 2001 and every time I've put it into storage, I've pulled the negative cable.
Months later, I've just hooked up the cable, started the car, punched in the radio code, and driven the car home. 4 or 5 times at least....
