986 2.7 power loss
986 2.7 power loss
Needing some help and ideas…
Backround; car has 80k miles. Been quite little use about last years.. and there was Cel light with codes P1128 and P1130. -I was suggesting bad MAF or 02 sensor issue. -Car was running still ok.
Until same day when i got new maf, there was some slight power loss when accelerating hard +4000rpm. -And there was new code P0154 (O2 sensor) (with P1180 and P1130).
I replaced MAF (new Bosch part) and 2 02 sensors (before cat), Bosch parts too. -Cleared codes after that, no codes!
Still, there’s some slight power loss on upper rews.. Somehow it feels like car has more power when engine is ”cold”. -No any oil smoke or anything, idle feels normal.
What you say? Where i should go look problems?
Facts are there’s quite old spark plugs. Fuel filter are possible original (unknown if has it ever been replaced)
what you say?
what you say?
There has been a series of bad MAF sensors. Some reported receiving several and only when they swapped them into another car did it become obvious that the part was bad. See about 6 threads down. How many miles on the new parts and does the problem continue?
