Boxster & Boxster S (986) Forum 1996-2004
Durametric and Door/Hood Latches
Old 07-18-2019, 01:53 AM
Dr. C
Dr. C's Avatar
Default Durametric and Door/Hood Latches
Good evening.
I have intermittent double horn beeps when I unlock my Boxster. I'm assuming the alarm control module is reading a fault somewhere. I have checked the module itself and yes, it is perfectly dry and the connections appear clean.
Can the Durametric software read/test each individual latch?
Will it be able to determine exactly why I'm getting the fault code?
Thank you all.
Old 08-02-2019, 03:25 PM
indieworks
indieworks's Avatar
Yes you can lock and secure each door using the software so any failure should bring up a fault
Old 08-03-2019, 12:23 PM
Dr. C
Dr. C's Avatar
Thank you indieworks for your reply!
I called Durametric a day or two after my original post. They are very kind, knowledgeable people.
The gentleman I spoke with mentioned the Durametric software is only as smart as the car itself; it can't run a function the car itself isn't capable of doing. He couldn't confirm the software could test each individual lock/latch(?) on my 2001 986S.
Of course, my alarm issue stopped, at least momentarily, a few days ago... I'll keep everyone posted.
Again, thanks for your reply indieworks.
Quick Reply: Durametric and Door/Hood Latches
