Boxster & Boxster S (986) Forum 1996-2004
Yet another water pump with metal impeller story...
Old 03-14-2019, 08:10 PM
tt9714
tt9714's Avatar
Default Yet another water pump with metal impeller story...
Documentation on why a water pump with metal impeller can cause irreversible damage.
This is a subset of my ongoing thread: "What's my next move?"
https://rennlist.com/forums/boxster-and-boxster-s-986-forum/1126901-what-is-my-next-move-4.html
Photos below show comparisons of:
  • LEFT: original block / genuine Porsche water pump (plastic impeller); 28K miles
  • RIGHT: replacement block from engine swap / aftermarket water pump (metal impeller); mileage unknown
Besides the coolant gelling problem (green + orange = gel) you can see the damage to the block on the right.
I measured both original & replacement block and average difference is (0.31) mm between replacement & original.
Now I have to make a decision:
  • Choice 1: take my chances with swap engine (risk from gelled coolant & risk from case damage)
  • Choice 2: return engine to seller, absorb $450-500 return shipping fee, and look for another engine
LEFT: genuine Porsche; RIGHT: aftermarket with metal impeller AND gel
Old 03-14-2019, 11:14 PM
Brian in Tucson
Brian in Tucson's Avatar
Have you run this by the seller? That damage is not good. Might be okay with a proper water pump, but would you be satisfied?
How far away is the seller from the south bay?
Old 03-15-2019, 10:13 PM
AnthonyGS
AnthonyGS's Avatar
That is terrible. Sorry to see the damage to your block.
Old 03-22-2019, 06:35 PM
Porschetech3
Porschetech3's Avatar
Received 4,325 Likes on 1,961 Posts
My .02 cents/ opinions.
The Porsche green/pink(orange) coolant is compatible/mixable and will not gel. Other formulas maybe, but Dexcool is known to be the most recognized offender.
I would be suspicious of an intermix of oil causing the gel/mayonnaise gel like substance, from either a previous or present intermix condition.
That engine should be carefully evaluated or returned. Surely I would expect the seller, if a business with a warranty, to pay for return.
If you are stuck with the engine, I would carefully evaluate for an intermix condition. Then after conclusion, look to the water pump efficiency issue.
If the block wear/score is smooth and not grooved and only 0.31mm deep, I would measure the gasket thickness. Use a 0.31mm THINNER gasket or sealer to restore the water pump efficiency back to factory specs. Note : carefully bolt the WP back on the block and rotate by hand to ensure no contact of the impeller to block. Hope this helps..
Old 03-23-2019, 04:18 PM
Charles Navarro
Charles Navarro's Avatar
Received 1,071 Likes on 557 Posts
I'd return it. I also don't like that whoever was working on the used engine copper-coated the water pump gasket. Makes me think they re-used it and question what else was done to that engine. The returned shipping cost might be the lesser evil.
Old 03-23-2019, 04:33 PM
Brian in Tucson
I agree.
Quick Reply: Yet another water pump with metal impeller story...
