Kaapoooowww! IMS failure happened to me - Page 3 - Rennlist - Porsche Discussion Forums
Old 03-13-2019, 03:03 PM
  #31
Tim Lawton
User
Originally Posted by AnthonyGS View Post
Yes 03 or later with vario cam plus.
yup....and it made a bunch of difference in bottom end torque as well....
tim
Tim Lawton is offline
Old 03-15-2019, 03:39 PM
  #32
Tim Lawton
User
Well, I pulled the trigger on a used M96.24. It's coming from an LA firm that specializes in Porsche stuff. They claim it only has 68k miles on it. It was the best motor I could find and the price fit my budget.
The rebuilds I found were in the $8.5K range to $11k. I would dearly have loved to put a fresh rebuild in it, and very possibly, I may regret not having sold the farm for a rebuild.
We shall see...…….
tim
Old 03-15-2019, 05:21 PM
  #33
AnthonyGS
AnthonyGS's Avatar
I sure hope this works out too. Do you have plans to replace the IMS bearing, water pump, and AOS before installation?
AnthonyGS is online now
Old 03-15-2019, 05:58 PM
  #34
Brian in Tucson
User
We shall see...ůů.
tim
Sounds like you did well. You don't really need a rebuilt engine--do the IMS bearing, RMS, & the AOS and it should be good to go. I'd probably throw a tune up in it too--plugs, tubes, and coils.
Brian in Tucson is offline
Old 03-15-2019, 06:18 PM
  #35
Tim Lawton
User
Brian and Anthony,
I had that discussion with my "wizard" on Monday.
The plan is to swap all of the good stuff of the dead motor (just put in new plugs and coils), as well as the IMS, and AOS...all of the stuff that normally goes bad at the wrong time.
We will also run our own compression and leak down test as well before installing the donor motor. It would seem to me if the "donor motor" made it this far, the rings and bearing are probably good.
My "wizard" is fairly upbeat about it. He has been servicing a '99 for almost 300,000 miles and just did the regular maintenance on parts that just wear out and also replaced the IMS early on.
He said it runs just fine, but has got to the point where it does burn some oil....not bad, I'd say...
We shall see...……..
Thanks for every body's input and support through what has been a depressing situation....
tim
Old 03-15-2019, 10:16 PM
  #36
AnthonyGS
AnthonyGS's Avatar
Sounds like a good plan. I look forward to hearing about you driving it again soon.
Old 03-16-2019, 03:11 PM
  #37
mikefocke
User
Water pump too. I like spending your money.
mikefocke is offline
Old 03-16-2019, 03:38 PM
  #38
Tim Lawton
User
Mike,
I had a kind of second job doing rigging work on sail boats and installing electronic systems. I really enjoyed being given carte blanche to spend an owners money...I was like a kid in a toy store....
And yes, a brand new water pump. I know they can be fickle....and expensive to change out. I'm trying to be as preemptive as I can while the motor is on the bench.
BTW, what is the link to your website?
tim
Old 03-16-2019, 05:44 PM
  #39
Brian in Tucson
User
Mike,
tim
Saved in my bookmarks:
https://sites.google.com/site/mikefocke2/mikesporscheboxsterwebpages
Old 03-16-2019, 06:49 PM
  #40
Brian in Tucson
User
Nice write up on changing out the AOS, Mike! Thanks!
Old 03-17-2019, 08:19 PM
  #41
digs
User
Good luck with the project moving forward , hope to hear a success story !
digs is offline
Old Yesterday, 11:28 AM
  #42
Tim Lawton
User
Yeah, me too...
I'll keep all of you posted as to how this ordeal turns out.
tim
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
