Forever CEL
Forever CEL
99 Boxster Base...After new Bank 2 solenoid/MAF/AOS/Battery/Plugs/Actuator Ramps both banks,I'm right where I started CEL P1539 and some misfire codes here and there...Brought to indie....said could be bent valves/actuator or timing....bailed on me....car is now at another indie. Any thoughts....car actually runs and sounds well with a little lacking in pickup. Any thoughts??
Have you had the car on a Durametric?
Indie had it on a PIWIS said there was power to the actuator but wasn't moving. So I guess I should of replaced the entire actuator. I had done a compression test and got 145 's bank2 and 195's in bank 1. Indie also thinks bank 2 my have bent valves. Not sure what to do at this point.New actuator and valve job just do an entire engine swap buy used head....no clue.
