Tire Pressure Monitor
The transmitter for one of my tires has joined the big Michelin man in the sky so now I continue to get an error message, menacing red exclamation point, etc. My dealer tells me that it would cost $1250 to fix this so what I'd like to do is to somehow tell the computer not to send me the error message. I wonder if anyone has any ideas.
Thanks in advance.
Thanks in advance.
Ok, so you have an 987 and should be posting in the 987 forums.
Having said that, I would think you would be able to buy another transmitter (433mHZ) and have it installed and programmed at any high-end tire shop. A quick amazon search shows many options that are less than $50 for the transmitter.
I should mention that TPMS transmitters have limited battery life. If one is dying, chances are the others will go soon, so you might want to just replace all 4. Check out https://www.tpms.com/2010_Porsche_Bo...PMS_s/4991.htm but you can likely find them cheaper elsewhere.
