Condensaton inside rear window
After driving in rain and letting the car sit, engine off, I am getting a small amount of window (hardtop glass) condensation at the bottom of the window. I am guessing from the engine compartment that is bypassing the cover and upholstery. Anyone else have the problem? If you identified and fixed, How?
Originally Posted by ddodgen
(Post 15530515)
It is important the engine cover be properly installed and secured. That every one of the screw locks be tight. I had this cover off very seldom but it always went back on without a hitch and always sealed the engine compartment. If the engine compartment cover is secure my WAG is there is a water leak, water is getting into the cabin. This can be from the hardtop failing to seal properly. Be sure the rear body water drains are not blocked. To get to these will probably require the top be removed. (For access with the soft top the procedure was to put the top in the service position which had the clam shell wide open. The rear body water drains are located on either side of the rear of the soft top under the area covered by the clam shell arms.) Might as well check the front body water drains too. These are located under the plastic panels on either side of the battery box. Check along the door bottoms for any signs of dampness. With these cars getting up in age the door membranes will start to go bad and when they do they let water from the wet side of the door into the dry side and this can have water seeping out the door into the cabin. Even if the water remains in the door this build up of water can cause door/window electrical "gremlins" to appear and if ignored can then have electrical gremlins showing up at other areas of the car. |
(Post 15530515)
Originally Posted by dr914
(Post 15532165)
you probably have a leak somewhere, maybe down in the rear well where the top is stored and the drain is clogged. Maybe capture a dehumidifier inside the car to dry it out before anything gets damaged
try contacting woody aka itsnotanova via a private message on the 986forum.com. He parts out wrecked Boxsters. Honest and helpful.
Originally Posted by mikefocke
(Post 15532787)
Woody had the part and shipped to me quick. Thanks
