DME question
Would a DME/immobilizer/key from a 987 work in a Boxster? Might be picking up a 07 S 3.4 that I think the immobilizer got wet. Haven't found any that are listed for a boxster but have found plenty for a 987.
It's my understanding the Bosch DME/immobilizer/keyfob is specifically programmed and coded to the VIN in the 987. In order words, it won't work. And, I'm pretty sure Porsche will not reprogram them for your car.
So what happens if the immobilizer goes bad? Everything must be replaced?
Just having difficulty finding everything for a Boxster, figured ones from a Caymen would work. |
Originally Posted by stl_986
(Post 15528203)
Just having difficulty finding everything for a Boxster, figured ones from a Caymen would work. https://rennlist.com/forums/boxster-...and-alarm.html |
I know for a fact that for a 98 the dme/immobilizer/key can be swapped from another car and not need programming. Otherwise someone like ecu dr wouldn't be able to do their exchange program.
(Post 15528336)
Seriously... you said you were considering buying a DME/keys/immobilizer from an '07 987 that had a "wet immobilizer". That tells me the immobilizer is probably not functional anymore. Therefore, that leaves you with a DME and keys only. Were you hoping the immobilizer would work? Trying to mate a newer DME system from 987 and install it on an older 986 seems like a fools errand to me. But good luck. Please report back good or bad. Cheers! :thumbup: |
