MY SINCERE THANKS
MY SINCERE THANKS
Since buying my Boxster in June I have played with a non working alarm and door lock system. I have tried almost anything including pricing out an after market system but after several members comments I found that I could lock the door manually with the window down and if I tried to open from the outside the alarm would go off. I also found that if I unlatched the front or rear trunks and then locked the car manually the alarm went off. OK and after making sure that the system under the seat was dry I guessed that the system was fine even though there is several places that have been taped with electrical tape. I decided to cross my fingers and get a new key fob, have it programmed by Porsche and hope that all would work. It took $140 and a half hour but all is well. Everything works.
Thanks to the members that suggested that an after market system should not be done. Your help and advice is appreciated.
The 986 era cars worked just fine with a key and none of the buttons working. Both my original key electronics failed and I never bothered to get either of them fixed. Most of the time I left my car unlocked. With a convertible, I wanted to make it easy for thieves to get in and find I had nothing there they wanted without ripping up the top.
