Boxster & Boxster S (986) Forum 1996-2004
99 boxster base clutch
Old 11-28-2018, 02:57 AM
vza
vza's Avatar
Default 99 boxster base clutch
Hi, Doing my clutch and new DM flywheel on 99 boxster base.Few questions.=left
=left
Torque for flywheel factory manual says 18 ft lbs + 90 degrees Bentley says 19+120 degrees think I'm gona go w factory manual..???=left
=left
Torque for 3 bolts for throw out bearing guide tube Bentley has nothing factory manual says 26 ft lbs I went with this and used Loctite wicking threadlock=left
=left
Factory manual says only grease input spline does anything else need to be greased in there??
thanks
=left
Quick Reply: 99 boxster base clutch
