Preferred brake pads for Track / Street use?
Hey y'all:
I've been running EBC yellows this year on my '03 Boxster S. The car sees about 50/50 track/street use. My home track is UMC (formerly Miller) in Utah. I;ve been unimpressed with the EBC pads; they fade quickly on the track and don't inspire confidence at all.
I'm looking to change to something else next spring. I've been reading about the PFC08 pads, which seem to impress most who use them. But I haven't found anyone using them on a Boxster yet. I've also heard form some locals that they use the Pagid RS39 (which I can't find, so I assume they meant RS29?). But reading-up, they don;t seem to compare favorably to the PFC08.
Do any of y'all have first hand knowledge & experience with either of these? Are there other pads that y'all are using which you're happy with?
Hit me!?!? haha
Hit me!?!? haha
on my 04S I have used Pagid RS29 yellow on the front and RS14 black on the rear. This has been a common combination for the 986. Can be noisy on the street but swapping pads is easy if the noise bothers. I've used the PFC 11 on a 987 Cayman and like them also.
So, are you racing with this combo? or DE? or?
I did a one day class with the Ford school at UMC, think it was the West part. Would really like to go back some day, but it's a long way from Tx.
RS29 front and RST3 rear is a common Pagid application for Spec Boxster.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Basic Sponsor
Give the Ferodo DS1.11 a try. Ferodo has been around forever and they make an extremely high quality product. They are in a different league vs. what you've been using. They are wildly popular in the 991 GT3 market right now, and they are the most popular brand among our Essex Designed AP Racing Brake Kit customers.
You can see all of the options for your car here:
https://www.essexparts.com/my-vehicl...oxster%20S/986
You can see more about the compounds and brand here:
https://www.essexparts.com/brake-pads/ferodo-brake-pads
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Jeff Ritter
704-824-6030
you do have to chuck out the shims, the Pagids are quite a bit thicker than regular pads.
I've been using Raybestos ST-43 endurance pads for four years now. My recent set in my 2600 lb street legal 986 track car has 20+ days on them in int./advanced PCA DE run group at Lime Rock, the Glen and Palmer, have 40% remaining in front and 60% in the rear, between track and street around 12K miles. They work great cold on the street and have been nearly silent, plenty of stopping power and torque on the track. Not even interested in trying something else next season, love em. Porterfield cuts them custom for 986, takes about 2 weeks to fill a order. https://www.porterfield-brakes.com
I run Hawk DTC 60s on my 2009 Boxster PDK Sport, Sport Plus in the front and OEM on the back. Have a friend who has a serious Cayman S who runs them front and back. Excellent pads and much less than Pagids. They are track only, too squeaky AND cold nature for the street. Once you get the Porsche OEM pads off with the silencer plugs they slip in and out. Suggest a cheap OEM equivalent for the street that you can change without removing the brake caliper. Depending on how often you run and change rotors consider a brake caliper stud kit. The aluminum threads in the knuckle for the brake caliper bolts are prong to damage. $125 a set, $250 for front and back. Get the stud kit for the brake line bracket. You need to remove the brake line bracket to get a little more flex room to remove the calipers with the studs. The brake line bracket is a blind tiny bolt on the back of the knuckle also prone to stripping. The brake line bracket stud makes it much easier.
