Need help with dual mass flywheel...
So I had a new clutch & flywheel installed (sachs). The flywheel makes a loud whining sound every time I shift & let out the clutch. Also, makes a lot of nosie when decelerating. Also has a vibration around 3,000 RPM.
Mechanic seems to think its normal. Its been 10 years since I've owned a 986, but I don't remember it making all this noise.
Best get the car back to the shop that did the clutch. Almost certainly the transmission will have to be removed and a sanity check made of the work done. The work doesn't have to be bad though. A new release bearing properly installed can suffer from premature failure.
