986 transmission and motor mount install: question?
So I'm installing Torque solution transmission mounts and engine mount inserts.
1. For the transmission mounts, can you leave just remove the mount and not the triangle portion? Would that make it easier?
2. For the motor mount insert, is it easier to just remove the lower half of the mount and insert the sleeves?
Thanks in advance
David
Thanks in advance
David
Thanks in advance
David
Thanks in advance
David
I haven't done the motor mount yet. Will advise...after i tackle it.
You can leave the engine part of the motor mount attached. Just unbolt the chassis portion from the body and the engine portion and it will slip out. I would suggest using a jack and a wooden block to support the front of the engine while you're doing this.
The trans mounts you'll need to remove the whole assembly then install the new mount and put it back in. Pull the right one first, then the left, more room that way, then do the disassembly and reassembly, Put the left one back in first, then the right.
I'm doing the motor mount tomorrow... thanks for the tip.
I've done trans mounts on a 986 and 987 and neither time did I need to remove the triangles. An 18mm (iirc) ratcheting wrench goes onto the lower bolt without a problem, then just knock off the 2 top bolts, lower the tranny a bit and they come right out.
Motor mount...while I spose in theory your strategy will work, putting the crossmember back over the motor mount inserts will be super tight if its anything like mine. Plus getting to the 2 crossbolts is a pain. Really, removing the two lower and loosening the 2 upper bolts and removing the whole mount will likely be quicker. It took me about an hour and a half and the worst part was getting the crossmember past the hoses.
