Front end squeak/creak won't go away!!
I tried slitting a tiny hole in the lower ball joint boot and sprsy wd40, and I did that a few times and the noise won't go away. Do I just need to replace it or is this not my issue? Any help appreciated. I can upload a video if needed. Please help
Received 5,388 Likes
Well, WD40 is not a very effective lubricant for that application.
WD40 is a solvent. Not a lubricant. It's essentially washing away the little grease you have left.
Have you checked the condition roll bar bushings? Could be a number of things. Look for excessive dirt/oil on any of the front suspension parts to help determine/eliminate the culprit.
