Boxster & Boxster S (986) Forum 1996-2004
Upgrade Base 986 Brakes to S
Old 03-16-2018, 06:37 AM
Rod Cederblom
2nd Gear
Rod Cederblom's Avatar
Question Upgrade Base 986 Brakes to S
I've searched a couple of hours & not found on-point discussion. What's involved in upgrade 1999 base 986 front brakes to 986 S ? Rotors increase 298 x 24 mm to 318 x 28 mm. Is there an adapter to move the caliper up or are S calipers & carrier change needed? I have 17" OEM wheels. Seems like this could be an inexpensive upgrade as rebuilt S calipers & new S rotors are available from many sources. Thanks.
Old 03-16-2018, 08:31 AM
Slakker
Slakker's Avatar
Calipers, pads and rotors and you are good to go. You can also use the ones off of a 996 C2 or a 987 as they are the same as the 986 S calipers. No spacers required.
FireCayman (07-06-2021)
Old 03-30-2018, 05:09 AM
GVA-SFO
GVA-SFO's Avatar
If you look for front rotors, I still have a pair of 986 S, that I removed from my car, when I bought a Brembo 6 piston large floating rotor kit.
They are in great shape, only 3 or 4 thousand miles.
(I do not have anymore the original S Calipers, sold these already !
Send a pm if interested.
Old 03-30-2018, 10:22 AM
Quadcammer
Quadcammer's Avatar
Received 1,368 Likes on 792 Posts
why do you want to do this? Spec boxsters run stock brakes. On the street, or even moderate track work, the stock brakes are more than adequate with a set of better pads.
Old 03-30-2018, 06:59 PM
GVA-SFO
GVA-SFO's Avatar
Pleasure and performance on track.
For example, gain per lap of this mod at Laguna Seca is around 2 sec. !
(I do not care to be in or out of the "spec", as I do not race.)
I can tell you that such setup makes a great braking difference over the OEM one.
Or, good to understand that better braking power ..is as important as better acceleration power (more HP on engine).
I do not know why, but everyone understand that more power is "top", while only very few would understand that more braking power is as important as engine power, i.e.: your comment : oem brakes are good enough !
For me, I see your comment like : the Boxster S (3.2 in my case) power is good enough.
Did you noticed that the last version of the Boxster Spyder do have also 6 pistons large rotors front brake ?
Old 03-31-2018, 10:00 AM
Quadcammer
Quadcammer's Avatar
2 seconds at MRLS? I'd need proof of that one.
On the street its totally pointless.
Old 03-31-2018, 10:50 AM
Slakker
Slakker's Avatar
2 seconds seems about right to me. .5s for the increased braking and 1.5s for the improved confidence in the brakes.
Quick Reply: Upgrade Base 986 Brakes to S
