Boxster & Boxster S (986) Forum 1996-2004
New to porsche code p0430 catalyst
Old 03-10-2018, 02:59 PM
Macdaddy357
2nd Gear
Macdaddy357's Avatar
Lightbulb New to porsche code p0430 catalyst
Hey all,
new here to porsche and forum, engine light just came on in 2001 boxster s. Says catalyst efficiency but i also noticed oil around my rims and rear wheelwells. Any ideas?
Old 03-10-2018, 06:39 PM
Anker
Anker's Avatar
Get a code reader on it that can read the Porsche-specific codes. Also get the car on a lift so you can check where the oil leak originates. It can be quire hard because the oil blows back in the slip stream.
Catalyst efficiency could be a failing O2 sensor, not expensive, or it could be a failing cat, quite expensive.
Old 03-10-2018, 06:44 PM
Macdaddy357
2nd Gear
Default Thanks
thanks for replying, i will check under the car, feels like a little power loss too
Old 03-12-2018, 11:48 PM
Boxzilla
Boxzilla's Avatar
clear the code, swap the post cat oxygen sensor to the alternate side oxygen sensor and see if the code follows the sensor from bank 1 to bank 2. If it does = bad sensor if not, bad cat
Quick Reply: New to porsche code p0430 catalyst
