Boxster & Boxster S (986) Forum 1996-2004
2001 Boxster Battery/Starter
Old 02-22-2018, 07:16 PM
Apsmith
Apsmith's Avatar
Angry 2001 Boxster Battery/Starter
Afternoon all.....I have a 2001 Boxster that has been garage kept for a while for a number of reasons. It has had a dealer added trickle charger so that the battery would not die. I pulled the cover off yesterday and it would not start. Took the battery out and my auto parts store gave me a replacement battery which I installed this morning and the car started right away. Left it running for over an hour while I washed it and even took it for a lap around the block. Once I parked it and turned it off it would not start again. The dashboard indicator lights flickered on/off and all I got was the dreaded clicking sound while I tried to start it. Thoughts and/or advice? Thanks in advance!!
Old 02-22-2018, 10:01 PM
Anker
Anker's Avatar
Did you fully charge the replacement battery?
Old 02-23-2018, 11:33 AM
Bill in VA
Bill in VA's Avatar
Are you sure the you have good contact? Cable terminals clean and secure? Could you have a defective cable that is giving you intermittent contact?
Old 02-23-2018, 06:32 PM
Brian in Tucson
Brian in Tucson's Avatar
Sounds like a loose cable. Most automotive replacement batteries are sold fully charged, btw.
Quick Reply: 2001 Boxster Battery/Starter
