Take a chance or leave alone
I have run across a 1998 Boxster with low miles (20K) that has not been driven in years. I've been looking for a project car to turn into a daily driver. There are several things that need to be done to the car before driven again but my biggest concern is possible IMS bearing issues. Should I move on or take a chance with this car? Would you go ahead and replace the bearing sooner rather than later? Appreciate any words of wisdom from owners experienced with this issue.
Based on my understanding, IMS problems show up in the first 100k miles or not at all. 20k miles? I think I'd replace it (or have it replaced). I think it's at least a $1,500 procedure at an indy (but I'd certainly check on that), so figure that into your offer.
Any idea of the maintenance history specifically the oil changes? Was the IMS bearing sitting in clean oil or with lots of condensation?
18 year old brake fluid?
Stored indoors?
Tires date of manufacture?
I'd worry about fuel system issues as much as anything. Injectors, tank corrosion, fuel filter.
Stored indoors?
An IMS bearing can fail at any mileage. Early failure from manufacturing tolerances. Later from wear, oil contamination, seal failure, pulley failure, low oil level, oil filter valve failure, etc.
With such low miles, if bought for the right price you can fix it and still have a decent resale value.
I recently picked up a one owner 1998 boxster with hardtop and roof rack. It was well documented since new but had been parked for a few years. (Im a sucker for one owner.)
I gave it a full service and it drives really nice. So nice in fact that i am pleasantly surprised how nice these little cars are to drive and for such little money.
I would go for it based on the miles.
Based on all the pertinent info you gave us, I'd say buy it, or maybe just run as far and as fast as you can. Sitting unused isn't good for mechanical things. Gas goes bad in practically no time, seals dry out, oil develops acids, tires dry out, brake fluid absorbs moisture and can corrode brake componts Wiring can corrode at connectors, Mice can build nests and pack rats can chew wiring. If it was kept inside for all those years, it'll be dusty but the top, the upholstery, and the paint should be okay.
Depends on the price. There's no such thing as a cheap Porsche. And more details and maybe some pics would be in order.
All of which can be fixed if need be, what you can't fix is 10 year old original paint & other cosmetic things. I would jack it up enough to remove the oil filter housing & inspect the filter for debris & oil quality. If all looks good start it up & drive it. If it drives ok, go straight to the shop that will install the new LN imsb.
There were some early Boxster engines that had a casting flaw after the casting machines was moved to a bigger location for higher production. To keep up with production these engine castings were "sleeved" to correct the bores, during "sleeving" the radius of the recess for the sleeve hat was not properly curved and would cause the "hat" to break off and the sleeve would slip down and contact the crankshaft. The result was catastrophic failure and usually happened at a low mileage of under 20k. It is thought that ALL these engines have already failed and have been replaced, but when I hear of an early Boxster with miles that low, it makes me wonder IF there are still a few of these out there. Sorry to be a bearer of doom and gloom, and I would probably still take a chance on it, but the price would have to attractive enough, and I love a good mystery.
