Grinding noise and vibration from the rear when turning (video with sound)
I went to an autocross the other weekend, and on that day my 1999 boxster developed this terrible grinding from the rear when turning at speed or under load. I've had the entire suspension checked over for play and was told it all looks good. CV shafts were checked as well.
https://photos.app.goo.gl/fMrHOSGg3PzS3LW83
Thoughts on what this noise is? It is not just a noise, you can also feel the grinding taking place. It is rather unpleasant as the video will show :P
But you have to consider something came loose and in a turn is making contact with a tire/wheel or some other part of the drive train or car.
Who checked over the suspension? Can't believe a brief road test by a tech couldn't allow the tech to identify the source of the noise.
I am going to try these FF1 reinforcements from Suncoast since I will be replacing my mount as well. Apparently, it will help prolong the life of the mount as it is a weak point on these cars.
https://www.suncoastporsche.com/suncoast-parts.htm
no, did you read the post? it was the front engine mount.
my car had the same horrible grinding noise under load in corners. once the mounts were replaced the noise went away
qwe (12-28-2019)
For those of you looking to use the Function First motor mount inserts, I had them installed late summer/early fall and have been great, and would recommend them. Some people in other threads reported serious vibration issues at speed but I didn't experience any of that, which means those who reported vibration issues may have other problems, or did not replace the motor mounts themselves.
Keep in mind, these are only the inserts you need which replace the factory inserts, and are not the mounts themselves. I recommend replacing both new motor mounts AND the Function First inserts.
Missed the follow up but I have to admit I was quite surprised it proved to be an engine mount and not a wheel bearing. Regardless I'm glad the OP found the problem.
